Mastra11
Jul 13, 2025Apprentice
Nintendo Switch 2 and Orbi 753 WiFi Information
Good morning, I have an orbi 753 system and a Nintendo Switch 2 that is correctly connected to 5GHz WiFi. The orbi router is almost next to the Nintendo Switch 2. However, I noticed something: when I...
Jul 13, 2025Guru - Experienced User
You are behind on FW. Could update FW and see.
Might try v.21 version first...
https://community.netgear.com/kb/en-orbi-knowledge-sharing/procedure-to-manually-firmware-update-orbi-and-nighthawk-mesh-systems-/2456254
Mastra11
Jul 14, 2025Apprentice
Hi, I decided not to update because the system is working fine. Then when I try to search for a firmware update on the router's page, it says there are no updates and it's already up to date. Do I need to install them manually now?
- FURRYe38Jul 14, 2025Guru - Experienced User
You can find current and previous versions of FW here: https://www.netgear.com/support/product/rbk752/#download
Previous link references how to apply FW manually
