David9
Aug 28, 2026Aspirant
Orbi 850 running V7.2.8.5_5.1.21 dhcp issues
Hi I recently switched my Orbi 850 back to router mode from AP mode as I have a new ISP. What i've found within a day is that the dhcp function on the Orbi 850 (+1 satellite) running V7.2.8.5_5.1...
Aug 30, 2026Guru - Experienced User
David9 wrote:What i've found within a day is that the dhcp function on the Orbi 850 (+1 satellite) running V7.2.8.5_5.1.21 is incredibly flaky.
The DHCP service is being provided by your ISP router, all the Orbi is doing is forwarding those requests to that router.
Are the two Orbi units in the same place as they were before?
Is the ISP router wifi turned off?
Any evidence of poor speeds on the connections that are made?
One possibility is that the ISP router can't handle that many connections.
- David9Aug 30, 2026Aspirant
Um no. I switched the Orbi 850 from AP mode to Router mode and connected it directly to the ISP, no other router in between. I made it the DHCP, as is the norm for you ISP router. It is this functionality that is flaky as hell, failing within a few hours. Couldn't connect any new devices. Cannot configure any timers.
