306Orbi
Jun 04, 2022Star
ORBI 963 - Best Way For Wifi
I have a Comcast Xb8 Modem inn Bridge Mode Connected to my ORBI 963E Router. The internet speed ORBI App Speed test shows is anywhere from 1375 to 1425 MBPS for download and around 42MBPS Upload. T...
- Jun 04, 2022
Sadly its something to test because the wireless backhaul is going to be different for everyone because everyone's home/neighborhood is different. 5ghz speeds drop off quickly with distance and interference. So disconnecting the wired backhaul and actually testing your speeds wired into the satellite is going to give you the most real world performance data versus us just guessing if it'll be faster or not.
I have a very similar setup and bought a cheap (ish) 2.5gig 8x port switch just for my wired backhaul between the router/satellites. This allows my satellites to have the same full 1.4gig speeds from xfinity.
Only caveat with this is that it isn't usually the satellites that are the bottleneck but the actual device you're testing on. Most of my wireless devices can't max out my speeds over wireless. Only a few can (my intel AX210 cards) and they have to be either close to the router or the satellite to do so.
Jun 04, 2022Guru - Experienced User
The intel AX210 is pretty cheap if you watch fleabay/amazon for it to be on sale. I put one in my desktop and swapped one into my laptop just for the 6E. Its a little more useful now with the 6E orbi than it was with my RAXE500. Still not the greatest as it doesn't have much range but its fun to test/play with.
the cat 5e is still holding in there nicely and upgrading it from gigabit capable to 2.5gig should get me a bit longer. Xfinity has been pushing speeds but they'll need docsis 4.0 to go much further. Plus i'm sure with more speeds, they'll raise prices. I'm already bumping up against my data limit more speed isn't going to decrease my data usage 🙂
