Chackett's avatar
Chackett
Re: Orbi RBR750 satellites not connecting to RBR750 router. Appear to be constantly rebooting??
I think I'm in the same situation as the OP and I want to make sure I understand what I need to do here.  I currently don't seem to be able to do ANYTHING with my satellites, and I gather the reason ...
  • FURRYe38's avatar
    Apr 25, 2025
    If the RBS failed to get updated first, then yes, downgrade the RBR back to what was loaded on it. Should get the RBS reconnected. Use there IP addresses to access there web pages and manually update them first, once they are updated, update the RBR.
    Have all the FW files downloaded to a ethernet connected PC for this. Unpack the .zip files.
    Use MS Edge browser.
    Connect to the web pages to update the RBS. Then same for the RBR lastly.
    Can follow this PDF Guide for this.
