MrcleanMC's avatar
MrcleanMC
Re: Possible Fix for iPhone Dropping WiFi
Hi all,
Just a quick note in case NG reads this that I've been struggling with the same issue for several months with the 960 and it has been driving me absolutely nuts.
I'm glad I found this thread and learned that 1) I'm not going crazy, and 2) this is a known issue and not just some one off thing happening to me on my iphone 15 pro.
I had an old RB50 set up in a fairly large 7000sq house that got signal on three floors, a basement and in parts of the yard.   It was stable and fine for many years.  This spring  I "upgraded" to the 963 and even went to the trouble of hard wiring it (was using wireless backhaul with the 50) and while the speed was faster when devices were properly connected, I didn't notice much in the way of better total range, and the device dropping issue is maddening.   What a let down...
Given the cost of their new systems, I really hope NG puts in the time to roll out a firmware fix ASAP.   Otherwise I'm going to ebay this thing and get a Ubiquiti system or something else....
  • FURRYe38's avatar
    What region are you located?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    How are the RBS connected to the RBR? Ethernet or wireless?
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Is the separate 6Ghz SSID network enabled or disabled?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    • choefler's avatar
      choefler
      Apprentice
      i have the same Problem, and I allready opened a Ticket by Netgear. This was in May, and since there is no fix by Netgear.
      • FURRYe38's avatar
        What model NG product do you have?
        What iOS device do you have?
        What iOS version do you have?
    • MrcleanMC's avatar
      MrcleanMC
      I have an Orbi 963 one router and I'm using 3 sats across about 7000 sq feet and 4 floors.
      Located in the US
      V7.2.6.31_5.0.24
      All wired with Cat8 Ethernet cable
      Using my own ARRIS Surfboard DOCSIS 3.1 Multi-Gigabit Cable Modem with 2.5 Gbps Ethernet Port instead of my ISPs modem.
      All wired satellites are more than 30' from modem and each other
