RonBZ's avatar
RonBZ
Follower
Jun 20, 2024
Re: Possible solution for Orbi dropping connection (when connected to satellite)
Yes it was turning off Access Control that stopped my RBS350 from constantly reconnecting. After 2 years same fault still exists.
1 Reply
  • FURRYe38's avatar
    What Firmware version is currently loaded on the RBS?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    What model RBR is the RBS350's connected too?
