Smugear
Dec 01, 2025Guide
random loss of wifi
Hi everyone, I have one RBR750 and 2 RBS750. I am working from home and my son is playing video games, so none of us like it when wifi suddenly drops and then a few minutes later the satellite blink...
- Dec 01, 2025
Concerete and steel will be problematic at best for any wireless system.
Lets turn OFF one of the RBS.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Smugear
Dec 01, 2025Guide
The RBS are all connected via WiFi to the router. The signal is good and the bandwidth as well. My problem is that the satellites drop the WiFi network (I see they later blink blue showing they are back). Why do they disconnect abruptly like that?
Dec 01, 2025Guru - Experienced User
- SmugearDec 02, 2025Guide
Thank you!
I have now set channel 01 for 2.4GHz and 48 for 5GHz.I had done a factory reset at the beginning of the year, so not since the latest firmware update. Should I?
Besides:
- 20-40 Mhz Coexistence is enabled
- WMM settings is enabled for both 2.4 GHz and 5 GHz
- Preamble Mode is Automatic for both 2.4 GHz and 5 GHz
- Transmit Power Control is at 100% for both 2.4 GHz and 5 GHz
- In the Administration Logs, I find an "[Internet connected] IP address: 192.168.1.21" event everyday, twice a day, systematically at 06:00:16 and 18:00.18. Does it mean it regularly disconnect and reconnect every 12hours?
- FURRYe38Dec 02, 2025Guru - Experienced User
What brand and model# is the ISP modem or ONT?
The Internet Connected IP address shows that the RBR is connected to a router upstream. Would not be recommended. And if your seeing this twice a day, should only be seen once in the log if the RBR is not being rebooted or power cycled. Means maybe something upsteam is happening which maybe causing issues at the RBS.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
Lets check this first, then try a factory reset as last resort.
- SmugearDec 04, 2025Guide
Thank you for your detailed guidance.
My RBR is currently configured as an Access Point, not a route. My ISP modem is the router, and I know that my ISP doesn't all me to change that (I'll ask again, maybe it has evolved...)
Since I've configured the channels differently, I haven't experienced the satellites dropping the wifi again. I'll continue monitoring until the end of the week...
