Stefan3189
Mar 10, 2026Aspirant
RB760 cable upload speed capped at 100mbsp
If I connect my laptop through a cable to my orbi, the download speed is correct at 1gbps, but my upload speed is capped at 100mbps. If I unplug my orbi and connect my laptop directly to the interne...
CrimpOn
Mar 10, 2026Guru - Experienced User
Have you tried swapping out the cable used to connect the laptop to the router?
- Stefan3189Mar 10, 2026Aspirant
Yes I did, I used both cat6 and cat7 cables
