Stefan3189
Mar 10, 2026Aspirant
RB760 cable upload speed capped at 100mbsp
If I connect my laptop through a cable to my orbi, the download speed is correct at 1gbps, but my upload speed is capped at 100mbps. If I unplug my orbi and connect my laptop directly to the interne...
CrimpOn
Mar 10, 2026Guru - Experienced User
Assuming that "1G" is an approximation and the actual speed displayed is slightly under (i.e. above 900Mbps, but less than 1000Mbps).
Is the 100Mbs speed also "slightly less"?
The question FURRYe38 asked about what the router shows for the WAN port on the "Show Stats" page is important.
- Stefan3189Mar 11, 2026Aspirant
Yes, that's the case. Download is now 1063 mbps and upload 109 mbps
The WAN port shows 1000M/Full
I will get a switch tomorrow and try to connect it in between my orbi and laptop- FURRYe38Mar 11, 2026Guru - Experienced User
What configuration were you using for this result?
