espcar
May 27, 2026Star
RBK852 Unable to connect to admin web/app
A bit like the issue with the RBRE960, I now longer can connect to the admin ui of my RBR850 anymore, and the app doesn't seem to find it either. I suspect the issue started May 23rd, when I got a n...
espcar
May 27, 2026Star
I'll give this a try in the weekend.
My experience with the backup and restore on this device and the RBK50 back in the days was that it's really not working well.
When restoring, the network always acted in weird ways that never happened when you did a factory reset and manually configured everything as before.
May 28, 2026Guru - Experienced User
Can try loading a saved back up if you have one.
One thing I try to do for helping to ensure saved backups are of good quality, after a system is setup first or from a factory reset, set up the system initially, get the basics going. Then save off one back up at this point. Then any additional features and configurations you enable or input, then save off another backup to file. That way you have two options for back up, if needed. I also tend to have backups for each FW version as well as sometimes as FW graduates, it may reveal issues with older versions of backups generated from prior versions of FW.
