chris38
Feb 03, 2026Aspirant
RBR 760 satellite
Hi i have a orbi rbr760 with 2 satellite, i want to add an other satellite but i don't found the same reference. is there an other version is compatible with RBR760 ? Thanks
Feb 04, 2026Guru - Experienced User
How big is your home?
There's been a few times, we've actually seen people have to many satellites and it causes issues with roaming and stability.
A router and 2 satellites should cover a fairly large home (provided it isn't made from brick/concrete/plaster lathe)
- StephenBFeb 04, 2026Guru - Experienced User
Agreed.
chris38: Before you purchase, I suggest checking the signal strength around your home using a wifi analyzer on your phone. If you are seeing RSSI values of -70 dbm or better, then you should have good whole-house coverage.
If you see an area where you are getting -30 dbm or better from two or more mesh elements, then you likely have some interference. If that is your situation, you could repositioning the satellites. Or try one of them off.
- chris38Feb 04, 2026Aspirant
my house is with 3 level, the modem is in the middle, i don't have issue with the wifi inside
but i have camera outside and i don't receive the wifi on 1 side of the house outside
is why i want to put an other satellite for the outside
did you have a good app for ios for analyse the wifi ?
Thanks
- plemansFeb 04, 2026Guru - Experienced User
Whats the exterior of the house made of? Things like metal siding, concrete board, brick, etc are all great at blocking wifi.
If you have those, its then trying to find a way to get the signal outdoors.
