MalV
Mar 12, 2026Aspirant
RBR750/RBS750 Firmware Question
Hi All, Have the RBR750/RBS750 system. The Orbi app does not work on my Android phone, just a white screen. Support stated my firmware is not up to date on my systems, so probably that is why app...
Mar 13, 2026Guru - Experienced User
Try the direct update. If it fails, go back 3-4 versions and try it. Just make sure to do the satellites first.
