BB69
Jun 11, 2026Aspirant
RBR760 with firmware v6.3.8.5_1.4.80
Exact same issue here, using RBR760 with firmware v6.3.8.5_1.4.80 terrible muisance!
BB69
Aug 19, 2026Aspirant
After spending some more time troubleshooting, I have been able to consistently re-produce the loss of configuration on reboot. It happens when a RBR760 reboot is initiated while any backhaul is in 'config sync' status. I think this should be enough detail for Netgear engineering to re-reproduce this issue and get it fixed in a new firmware release.
Any updates, please update your support case regarding this.
Aug 19, 2026Guru - Experienced User
So if the config sync is not the status and status is GOOD, the config remains thru a reboot?
- BB69Aug 19, 2026Aspirant
Correct, if the backhaul status is 'Good' or 'Poor' or 'Disconnected', the router will reboot just fine and come back online with unchanged configuration.
