stephenramsden's avatar
Jul 04, 2024
Re: RBR850 WAN stuck on 100m/full
I have the same exact problem with an RBR850 where the Wan port is stuck at 100/full.
I got all the way up through level two tech-support at Netgear until the guy finally decided it must be an internal hardware issue and they arranged an RMA to replace it.
This router was already a replacement router for unknown hardware issues with the first RBR850 router that I had been using for about three years.
It’s very frustrating.
  • CrimpOn's avatar
    CrimpOn
    Wow.  Did you purchase an extended warranty?
    Please post how things work out with the RMA unit.  Would you mind describing the tests Level II support went through. i.e.
    • swapping cables?
    • connecting directly to the modem?
    • doing that fun loopback test suggested by plemans in message 10?
    • stephenramsden's avatar
      stephenramsden
      level one tech had me factory reset the router after backing up the configuration settings and then reinitialize from start up, and restore the configuration settings.
      He also asked me to change the DNS servers to some dummy numbers all eights and a couple of fours. And we went from WPA to WPA two/ WPA three security protocols.
      The level three tech guy just had me do the router reset without returning the back up configuration settings and just looked at the statistics for the WAN still being stuck at 100 Mb/Full And decided it was an internal hardware problem and nothing else could be done.
      The first replacement router I purchased on my own to solve the other problems I was having. This began to happen inside the 90 day hardware warranty for the new router so I was able to exchange it for a small fee. I have not received the new router yet.
        stephenramsden
        I should add that the router and satellites all worked perfectly during this entire affair except that they were capped at 100 Mb per second.
