guguwi
Oct 11, 2025Follower
RBRE 960 with AT&T should firewall and packet filter be disabled?
Having IP Passthrough mode enabled on AT&T Fiber to RBRE960, should all the firewall advanced settings and packet filter be disabled on AT&T side?
CrimpOn
Oct 11, 2025Guru - Experienced User
My guess is that enabling Passthrough mode will do that automatically. If the Orbi router is not set to allow connections from the internet (OpenVPN or port forwarding), then it probably makes no difference whether connection attempts are stopped at the AT&T router or at the Orbi router.
