Ekkoh
Nov 20, 2025Tutor
RBRE960 DHCP issue?
I have an RBRE960 with three RBSE960 units. Two are wired, and one is connected wirelessly. I’m experiencing major issues with my devices losing connection to the network. My iPhone suddenly drops t...
Ekkoh
Dec 06, 2025Tutor
Thanks! That seems to have solved the issue with the satellites connecting via Wi-Fi instead of cable. However, my original problem has gotten even worse with firmware 7.2.8.5. I constantly lose the IP address on my devices and get assigned a 169.254 address.
Dec 06, 2025Guru - Experienced User
What devices are loosing an IP address? brand and model please.
How was the system updated? Manually or Automatic?
RBS first then RBR lastly?
After the system was updated did you continue to use the system or power cycle the system OFF for 1 minute then back ON?
Is the separtate 6Ghz wifi network disabled or enabled?
Ekkoh wrote:Thanks! That seems to have solved the issue with the satellites connecting via Wi-Fi instead of cable. However, my original problem has gotten even worse with firmware 7.2.8.5. I constantly lose the IP address on my devices and get assigned a 169.254 address.
- EkkohDec 06, 2025Tutor
iPhone 15 and 16. One on iOS 26, other on 18,6.
Two different ATV, both on 26.
MacBook Pro 2024 on Tahoe.updated manually. RBRE first. Then RBSE. Continue to use. Haven’t turned off.
6ghz enable.- FURRYe38Dec 06, 2025Guru - Experienced User
RBS should be updated first, then the RBR lastly.
Disable the separate 6Ghz network. 6Ghz is already running on the main WLAN with 2.4 and 5Ghz.
Power cylce the system OFF for 1 minute, RBS off first, then RBR, then back ON with the RBR then RBS.
I've just updated my system to v.5 FW, RBS first, RBR lastly then power cycled the system OFF then back ON. Will monitor.
Both RBS are ethernet connected to a XS505M switch behind the RBR.
Using manual channels 1 and 40 and 37.
I just got a iphone 17 in house so will check this along with other Apple devices I have.
