gr8campr's avatar
May 26, 2025
Resetting Orbi RBR 750 and RBS750 satellites to factory default
Good morning!  I recently upgraded my Orbi system to an Orbi 770 Series Tri-Band WiFi 7 Mesh System, 11Gbps, 3-Pack (RBE773) and would like to reset the old RBR 750 router and satellites to factory d...
  • KevinLiT's avatar
    May 26, 2025
    Hello gr8campr,
    Welcome to the NETGEAR Community!
    i understand that your would like to factory reset your RBR750 due to upgrading your system to the RBE771. A factory reset can be done without connecting to the internet. As suggested by plemans, simply hold the reset button for about 30 seconds.
    To successfully Factory reset your RBR750 please watch the video embedded in the link below:
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    Best,
    Kevin
    Community Team
