wce68
Aug 27, 2024Aspirant
Re: Slow wireless speed RBR850
I'm having the same issue with my fiber connection. I've completely turned off the satellites and stood 10 feet from the router with no real improvement. One of the satellites is using ethernet backh...
Aug 27, 2024Guru - Experienced User
What devices are you speed testing with?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
You might first save off a backup configuration to file now:
Then do a factory reset.
Setup from scratch and first test to see if wireless speeds are slow for you or not. If they are slow, then downgrade to v.21 and then factory reset and setup from scratch. Test again to be sure. If good, can try applying the backup configuration and check again.
- wce68Aug 30, 2024Aspirant
I've tested with MSI and Lenovo laptops, and with an Android phone. Similar results across the board. If I can get a large enough block of time to work through it, I may attempt the firmware downgrade. If I do, I'll report back here.
- FURRYe38Aug 30, 2024Guru - Experienced User
v.21 is the most stable and recommended version of FW:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2359585/highlight/true#M53030
You'll need to factory reset and setup from scratch after you apply the FW to the RBS first, then RBR lastly.Follow this for best results:
