Mastra11
Oct 08, 2026Apprentice
Strange PlayStation 5 and Netgear Orbi 753 issue
I have a Netgear orbi 753 that works well, daisy-chained to my FTTH provider's router with excellent coverage and speed. I don't have many devices connected, a maximum of 20 devices, and they all wor...
Mastra11
Ok, thanks, to disable Armor I can only do it from the Orbi app, right? Once disabled, you don't have to restart the router, right? Thanks.
Oct 08, 2026Guru - Experienced User
Correct. I would do a reboot on the RBR after Armor is disabled just to make sure the change as taken place for good measure.
