JeffGo
Apr 17, 2024Aspirant
Re: unable to flash router in 960 mesh system
There seems to be an issue with the .31 router image. Last week, I noticed that my satellites had auto-updated to 7.2.6.31 but the router had not. A few days ago, I ran the update from the web UI...
- Apr 26, 2024
Tried again this morning.
First, downloaded a fresh copy of the firmware file and unpacked it. Then did a manual update. Got a failure message at the end of the process, a few minutes in (I hadn't noticed that before).
Next, tried the online update ("recommended method" per UI). That succeeded and on reboot, the router is now showing .31.
So, fifth or sixth time is a charm.
Apr 17, 2024Guru - Experienced User
Did you follow this process to manually update the RBR?
I'd disable the auto update feature on the RBR as well for this.
Use MS Edge or Firefox to manually update the RBR.
I recommend if your seeing problems, factory reset the RBR and RBS and setup from scratch after you get the RBR updated to v.31. Factory Reset Process
- JeffGoApr 17, 2024Aspirant
Dude, I said I did a manual update (and I have over 10 years of experience with Orbis). Maybe someone can verify that after an update from .21 to .31, the UI still shows .21?
I can turn off auto update. It never worked on the 960 before, surprised that the satellites did.
- FURRYe38Apr 17, 2024Guru - Experienced User
Just checking dude. The PDF there details a recommended process to manually update FW.
I updated mine use that process as well and the version remained on the RBR.
I know that the user donawalt has his loaded and is currently working on his 960 series.- donawaltApr 17, 2024Mentor - Experienced UserYep- update to .31 went fine and shows on the 960 router as .31. Something is awry. Corrupted file? If I saw that happening, I would definitely do a factory reset and start from scratch. If you have a valid settings back up file, that’s not a big deal to do.
