DeaneHornsby
Nov 04, 2025Tutor
Zoom is continously displaying low bandwidth and screen sharing lags
I've been trying to solve a similar issue on RBR850 with three RBS850. running Zoom. Zoom is continously displaying low bandwidth and screen sharing lags (although it get there in the end) I followe...
- Nov 04, 2025
DeaneHornsby wrote:
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac
The VPN might be the real problem here.
Do you see this if you make a zoom call when not logged into the VPN???
DeaneHornsby
Nov 05, 2025Tutor
I have to say you gurus are super helpful. I was messing about for a while with this and finally found this forum. I didn't know if anyone would respond, but you did and I'm grateful for that.
Nov 05, 2025Guru - Experienced User
DeaneHornsby wrote:I have to say you gurus are super helpful. I was messing about for a while with this and finally found this forum. I didn't know if anyone would respond, but you did and I'm grateful for that.
I'm glad we could help.
