DoctorA
Dec 10, 2019Luminary
Red NG Banner above: Remote Management functionality not working using the Orbi app
"We have been made aware of an issue with Remote Management functionality not working when using the Orbi or Nighthawk app. This issue should now be resolved. Please create new discussion in the Apps...
- Dec 10, 2019
Solved!
Since NG said the issue is solved now I asked my son if he had changed the passwords and he said yes.
Make sure you put your admin password and not your WiFi password to login to your phone app.
Attached is my Network wired topology map.
