robertosimion89
Oct 04, 2022Follower
Regular logs + update firmware
Hello everyone, I have an Orbi RBR 850 router and 4 RBS850 satellites. On the router it is version V4.6.9.11 and on satellites version V4.6.8.5. I don't understand what the problem would be with them because in the logs it tells me that the internet is always connected at the same time.
Can someone help me?
Another thing. How can I prevent the router and the satellites from updating automatically? Or if it is possible for me to set the time interval for him to look for updates?
1 Reply
The RBS FW needs to be one same version of FW as the RBR.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopAnother thing. How can I prevent the router and the satellites from updating automatically? Yes. Or if it is possible for me to set the time interval for him to look for updates?
Review this:
