Rikerrock's avatar
Jun 01, 2023
Remote Administration: Can't seem to get it to work even though I've enabled it
Have a 850 unit with some satelites and I've enabled the remote administration (I want to be able to use my browswer to configure port forwarding and the app on my IPhone wont do that) and I've added the port and enabled it.  When I goto my address and port, it's just in a constant load and white screen.
What are my options to get this to work or do what I want.
Thanks in advance.
    • Rikerrock's avatar
      Rikerrock
      Tutor
      Most recent firmware is installed.
      I'd like to be able to login to the gui from my work and manage the orbi router from there via web browswer.  I thought that was what the remote administation page and settings are used for.
      Am I wrong?
      Is there a way to do this?
      Thanks
      • FURRYe38's avatar
        Would you please post a screen capture if this remote location please here in the thread for review.
