dbrb2
Dec 26, 2024Apprentice
Remote reboot RBR750
I have an RBR750 and an RBS750
At some point this evening, the RBR stopped acting as a wireless AP
It still has an IP, and can be pinged - but the web UI returns a code 500 error
I'm remote at the moment - is there anything I can do to reboot it without having physical access....?
Unsure what triggered this - it has been up and stable for weeks
It is working at some level - I can call the speedtest URL:
curl -s http://192.168.1.48/ajax/qos_result_check.cgi --data-raw check_bw=check -X POST -H 'Content-Length: 0'
+ DATA='98.00 Mbps;981.77 Mbps;2024-12-27 00:01:11'
But unaware of a similar URL to reboot - and the web UI is still giving 500
If you have Orbi app connected over Anywhere Access, you can use Orbi app to reboot the RBR.
If not, you'll need someone on site to power cycle the RBR OFF for 15 seconds then back ON.
What Firmware version is loaded on the system?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a factory reset and setup from scratch been performed since last FW update?
- dbrb2Apprentice
Ok.
I managed to get a power cycle done.
The unit came back up, with a new IP address, but is still giving a 500 error.
I can't do any more diagnostics until I am back home, likely in a few days. I haven't instigated a firmware update recently, but it is possible one was applied automatically I suppose some time yesterday....?
The satellite came up fine, and is running V7.2.6.31
The RBR is working in AP mode, not as a router, but that has been the case for months
what is giving you the error?
Trying to figure out exactly what you're trying to do and attempting to do with the remote access
