lagunatic
Oct 25, 2024Guide
Replace old RBR50 with RBR850/RBS850 (RBK852) - initial setup issues
I have an old existing RBR50 with an outlet-plugin satellite. Replacing with a brand new RBK852. Already been using the Orbi app on iOS but I uninstalled and reinstalled the app prior to attempting t...
- Oct 26, 2024
I don't have any issues saving config files using MS Edge, just the nag popup after selecting the backup button, that in the MS Edge download section I get the warning about downloading the file. The is 3 dots on the warning about the file. I select this then select KEEP and the file gets downloaded to the download folder is all.
Yes.
lagunatic
Oct 25, 2024Guide
It was odd to me that I couldn't connect to the router using http://orbilogin.net in an Edge browser yet the PC and Orbi app on iPhone could connect via Wi-Fi with default SSID/PW but they still said 'no internet'. Must be something simple I'm missing.
Thanks as well to you too for assisting. Much appreciated!
lagunatic
Oct 26, 2024Guide
Well ... I have no idea what changed from last night to this morning, but I was able to configure my RBR850/RBS850 just fine doing the exact same steps and then updated the firmware on both from v3.2.16.22 to v4.6.9.11 and changed the SSID/PW to what the older system was ... so strange it worked today. I'm on the internet and connecting. The Orbi app on iPhone also working as expected.
However, one minor item ... in Win11 24H2 if I hover over the internet connection icon in the Systray it still says the default SSID name versus what I changed it to. Is that a Win11 bug?, or is it changable? ... should I reboot cable modem/router/PC and see if it updates? It's not really affecting anything but would prefer to see the updated SSID.
If I go into the advanced admin console app, to see if there's more current firmware than v4.6.9.11 for the RBR850/RBS850, it says nothing is available. I will review the forum but does anybody have feedback on that?
Thanks again to all that replied to my post. Very much appreciated.
- FURRYe38Oct 26, 2024Guru - Experienced User
Manually update to v.21 on the RBS first, then RBR lastly if you want to get to v7 FW:
Soon after you get to v.21, disable the auto update check on the update section of the RBRs web page so it won't update to v.31. v.31 has problems and we can't recommend it.
Follow this to manually update FW:
- lagunaticOct 26, 2024Guide
Done, Done and Done.
Thanks all for your assistance!
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
