HarryGosman's avatar
HarryGosman
Follower
Dec 19, 2023
Reset RBS350
The satellites (RBS350) regularly malfunction (purple/blue lighting). I can only solve this by disconnecting the satellites from power. is there a setting to activate so that the satellite automatically resets.
1 Reply
  • FURRYe38's avatar
    What Firmware version is currently loaded on the RBR and RBS?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    What channel configurations are currently set on the router?
    RBS should not be reset or need any frequent rebooting. If this is happening then there is a problem that needs to be figured out.
