snakeking2's avatar
snakeking2
robi 753 router in AP mode connected to a GBE switch
this seems like a supported method - modem router to a GBE switch and the Orbi conected to one of hte ports of the Gbe switch.
used on this manner the speedtest function within the orbi app does not work - it say no connection while the Speedtest IOS app works just fine and i have connections to the wifi clients on the ORbi.
further in this mode with the XFi wifi also working i keep seeing in the connected devices on the XFI network whow up as wired devices on the orbi
any ideas?
i also had a support person tell me that the Orbi cannot be connected to the port of a GBe switch but must be connected directly to the modem router ethernet port? anyone can corroborate that?
thanks for any and all help!!
best
NM
  • plemans's avatar
    What modem/gateway are you using?
    What switch are you using?
    Is your orbi the RBk753?
    How exactly is it wired:
    for example:   modem model*---->switch----->router?
    • snakeking2's avatar
      snakeking2
      Thank you!
      So the topology is xfinity arris 1862L modem router connected to a 16 port TrendNet unmanaged Gbe switch. That switch is connected to rj45s thru out the house and the Orbi753 router is connected to the switch in the study.
      • Mstrbig's avatar
        Mstrbig
        Master
        snakeking2 wrote:
        Thank you!
        Sometimes having a switch between the ISP modem and Orbi causes issues. You are better off connecting the orbi directly to your Arris modem/router, then the switch. Then if you have satellites you can connect them to the switch.
