Premorange's avatar
Premorange
Router not connecting to modem anymore
First my Orbi app showed that the router is disconnected from the internet, but the satellites were still connected. Weird. I’ve reseted the router, now it does not connect to the internet anymore at all. My internet has not changed.
  • 1. What Orbi do you have and what firmware is it on?
    2. What is the make and model of the ISP router to which Orbi router is connected?
    3. Are the satellites wired or wirelessly paired with the router?
    • Premorange's avatar
      Premorange
      Hi, thanks for the quick reply mate. It’s a RBR750 router, bought December 2021. No idea about the firmware, it doesn’t let me go to that point. The two satellites are not wired. Thanks!
  • FURRYe38's avatar
    What Firmware version is currently loaded? Log into the RBRs web page at 192.168.1.1 with a PC and web browser to find the version.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
