brassakabruce
Jan 27, 2021Follower
Router not supported
For some reason I can’t find the model but it is Model #RAX10. AX1800 router. When I try to connect my Orbi RBK753S-100NAS. It says router not supported in the Orbi app. Do I have to buy a different r...
vajim
Jan 27, 2021Master
brassakabruce wrote:
For some reason I can’t find the model but it is Model #RAX10. AX1800 router. When I try to connect my Orbi RBK753S-100NAS. It says router not supported in the Orbi app. Do I have to buy a different router? The Orbi worked fine with my old Century Link modem/router. On my old router it plugged into the wan/lan port but my new router doesn’t have a wan/lan port. Just the internet port and 4 Ethernet ports.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
