ARNULFO
Jul 31, 2025Follower
Router RBR750
I have an RBR750 router, how many satellites can I connect?
CrimpOn
Jul 31, 2025Guru - Experienced User
Netgear says this:
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
i.e. performance is affected by the number of satellites connected to the router (backhaul) using WiFi and by the number of satellites which "Daisy Chain" through another satellite to reach the router.
So "more than 4 satellites using wireless connection to the router" and the more that can be 'wired' to the router the better.
If the goal is 10-20 satellites, no way.
