EmmanuelD
Jul 14, 2026Follower
Router RBR760 and CPL
Hello . I have a R760 Router + 2 satellites at home, but the reception is terrible on one of the satellites. I'd like to put CPL plugs between the said satellite and the router. Is there a specific s...
HappyCat
Jul 14, 2026Virtuoso
I have connected devices to my Orbi router using Powerline adapters. None of the equipment (router, satellite, devices, etc.) have any idea that Powerline is in use. All they see is that an Ethernet cable is connected on both ends.
Powerline is a complicated subject. One issue is that Powerline is not "Full Duplex" like a regular Ethernet connection. The maximum connection speed also depends on
- The actual wire distance the signal must travel. (speeds falls off dramatically with distance)
- Whether the connection is on a single electric circuit or goes through a circuit breaker box
- The physical condition of the electrical wiring
In general, look for Powerline devices with the highest speed rating. I have used TP-Link PA-9020 units for a number of years. The Netgear equivalent is the PLP2000:
https://www.netgear.com/home/wired/powerline/plp2000/
It is a good practice to first set up Powerline with the devices (router and satellite) located in the same room plugged into electrical outlets that are on the same circuit. After verifying that the Powerline adapters "work", then relocate the satellite to a remote location.
