DanaJones
May 09, 2025Aspirant
Satellite compatabiliy
I have a functional Orbi 770. Can I add satellite from my previous Orbi Network model is RBS20. If so, how? I have the Orbi app downloaded thank you
DanaJones
I live rural and am provided with Internet by a Point to Point wireless network called Ranch Wifi. Can my old Orbi 15 be utilized as a separate network for use to expand internet coverage to another part of our ranch provided I have Ethernet and Power? Thank you!
KevinLiT
May 09, 2025NETGEAR Moderator
Hello DanaJones,
Thanks for your response!
Your old orbi system can be used to create a separate network on that part of your ranch. However, it will not be connected to your RBE771 network and may require advanced configuration.
Best,
Kevin
Community Team
