DanaJones
May 09, 2025Aspirant
Satellite compatabiliy
I have a functional Orbi 770. Can I add satellite from my previous Orbi Network model is RBS20. If so, how? I have the Orbi app downloaded thank you
DanaJones
I live rural and am provided with Internet by a Point to Point wireless network called Ranch Wifi. Can my old Orbi 15 be utilized as a separate network for use to expand internet coverage to another part of our ranch provided I have Ethernet and Power? Thank you!
May 09, 2025Guru - Experienced User
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Can try AP mode configuration with the old Orbi system. Would need to make sure distances is far from the new Orbi system and using far apart wifi channels as well.
