netblokeusa
May 18, 2021Aspirant
Satellites dropping WIfi constantly. RBR750
I have gone through these forums looking for a solution....was sugegsted reposting in this sub forum...
So I use Xfinity.
My Cable modem is an Arris SB8200.
Orbi Router is RBR750 (purchased through Costco if that makes a difference)
Firmware Version
V3.2.18.1_1.4.14
It seems that my WiFi is a sporidically dropping (and has been for some undetermined time frame, it may be when I upgraded the Cable Modem a few months ago)
I never notice anything connected to the main router dropping but from satelites it dropps constantly.
Netgear support wants to charge me for the fix. they say it is some setting I have incorrect. I can't really afford to drop $90 for a new support contract.
Any ideas on what I need to alter?
1 Reply
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Traffic Meter.Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
