Mcarrelb
Feb 25, 2025Aspirant
Satellites RBS850 keep disconnecting from routers and Web console says no new FW avail!!!
For months now my RBR850/RBS850 is unstable. My satellites disconnect from the router and all attached devices cannot connect to wifi anymore. I have checked on the ORBI app and the ORBI Web con...
Feb 25, 2025Guru - Experienced User
NG sometimes doesn't push new FW soon as it's posted. May hold off or push out in batches.
Been known posters posting about v.31 not being a good version.
What do you mean by RBS disconnecting from routers?
Has this been happening since the system was last updated to v.31?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
- McarrelbFeb 25, 2025Aspirant
The satellites keep disconnecting from the router and this happened since V31.
I have 2 satellites on the upper floor and my router on the lower floor. House is 2700 sq ft and distance between router and satellites is easily more than 30 ft. internet provider is Orange (I leave in France); optical able with 1GB bandwidth up and down
- FURRYe38Feb 25, 2025Guru - Experienced User
Id manually update the system to newest FW version, RBS first, then RBR lastly.
Can follow this PDF on how to: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2359585/highlight/true#M53030
For that size of home, the RBR and just one RBS should be enough, with two, I'd turn down the power from 100% to 50%.
I did the upgrade as you suggested and also indicted in the documentation. All done and ok for now but I need to wait and see in the longer term.
How do you turn down the power to 50%?
In France houses are built out of very thick concrete walls; not like woods as you have often in US. Hence I needed 2 satellites. Welcome to my world 😊
