BenVaughan12
Nov 15, 2025Aspirant
"Self-assigned IP" on MacOS Sequoia when trying to connect via Ethernet
I'm trying to connect my MacBook Pro running MacOS Sequoia 15.7.2 via ethernet to my Orbi Satellite. I get the status "Self-assigned IP" in the Network tab in System Settings under the Ethernet Port'...
BenVaughan12
Nov 17, 2025Aspirant
The adapter is marketed as a 2.5gbps adapter; here's the link to it.
Nov 18, 2025Guru - Experienced User
BenVaughan12 wrote:The adapter is marketed as a 2.5gbps adapter
Did you try
- disconnecting and reconnecting the adapter from the macbook when the problem happens?
- rebooting the macbook?
This could be an issue with either the satellite multigig port or with the adapter.
If you have a second satellite, you could also try swapping them.
