Pauljabez
Apr 26, 2021Aspirant
Set-up ORBI RBR850
Hi All,
Today I purchased ORBI mesh system RBR852. I have a Netcomm NDD-0300 NBN modem supplied by TPG.
I installed it using the APP. the wifi is working fine, but there is no internet connection. I spent totally 6hrs talking to the technical support of TPG and Netgear. But the internet is not working.
Can anyone help me please.
Regards
Paul
Try powering OFF the ISP ONT device and RBR for 30 seconds then back ON?
Ensure your using good quality LAN cable between the ONT and RBR. CAT6 is recommended.
- PauljabezAspirant
Thank you for your reply. Netgear technical support said ORBI RBR850 will not work with Netcomm NDD-0300 FTTC NBN modem. I have to return and find some other solution.
Currently I have d-link DL-4320L modem/router which works fine, but not powerful enough for wifi signal to reach the first floor of the house. Do you have any suggestion?
On the D-Link modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
