tfraser91's avatar
tfraser91
Setting up Orbi RBK853 in Router Mode with BT FTTP
Hi All,
I currently have my BT FTTP going into my BT Router and then an ethernet cable going from the BT Router to the Orbi (in AP Mode) however, I keep encountering issues with this setup and am wondering if it would make things better if it was in Router Mode and did away with the BT Router entirely and if this is even possible however, I don't want to make things worse.
Is it simply a case of me performing the following: (?)
Changing the cable to go directly into the Orbi
Switching off the BT Router
Going into the Orbi Admin webpage, amending to Router Mode
Going into IPV6 settings and entering in 'PPPoE' credentials which are supposedly generic for BT such as:
Username: bthomehub@btbroadband.com
Password: BT
Has anyone done this recently? Does it work? Let me know your thoughts please and if there are any limitations such as 'this will very much mess up your Sky Q system or SmartHome systems etc' or whether this is and has always been the superior approach and will be the answer to all of my problems :D
Look forward to hearing from you.
Cheers,
Tom
  • FURRYe38's avatar
    Ask the ISP first if this is a supported option to remove there router. IF so it may work.
    • tfraser91's avatar
      tfraser91
      I called BT this morning and they said to get in touch with NETGEAR and ask them! No-one wants to advise it would seem but I could try calling back...
      • FURRYe38's avatar
        Why would they direct you to NG when it's THERE system and THERE HW and services. They should know if there router is needed or not. NG will not have this information.
        Otherwise, Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
