DWHITE4245
Dec 10, 2025Aspirant
Setting up RBK760 in Access Point mode
I am replacing my old Orbi RBR50 (Router + 1 satellite) system with an RBK760 (Router + 2 satellite) system. I'm in the UK and have a Vodafone FTTC broaband connection. The Vodafone Power Hub has no ...
Dec 10, 2025Guru - Experienced User
DWHITE4245 wrote:I thought perhaps I could set up the orbi as an access point and then connect it to the Vodafone Power Hub router
That should work, but you can easily just connect the WAN port of the 760 to the Power Hub, and connect to the 760 WiFi. Then reconfigure.
The process is the same, the only difference is that the internet connection won't be established if the WAN port isn't connected to your network. So you'd need to ignore the error messages.
