MKnichel
Nov 04, 2025Aspirant
Setup advice...
I have an RBR750 with 4 RBS350s. I want the DHCP to come from our firewall/router. I created a pool on the Firewall for WiFi and some access policies. My questions are: 1. When I connect the R...
MKnichel
Nov 05, 2025Aspirant
Another question comes to mind...
I have the RBR750 in a window on the ground floor of a 3 story building. I have 2 RBS350s on the 3rd floor. The building is an H config and the Router is near the crossover. You can go between each wing through a door and the RBS350 is hanging on the wall just inside the door. There is also a window next to the door. Total distance between the Router and top floor satellites is no more than 40-50 ft. if I had to guess. Maybe a smidge more...
I have these 2 other RBS350s that I was considering putting on the second floor in similar location as third floor units. Can the RBR750 connect to 4 RBS350s wirelessly? I am assuming that the 22nd floor units would be connected direct to the router and the 3rd floor daisy chain through the 2nd floor units?
I read that NetGear recommends only 2 daisy chained satellites. Am I asking too much from these 350s?
