MKnichel
Nov 04, 2025Aspirant
Setup advice...
I have an RBR750 with 4 RBS350s. I want the DHCP to come from our firewall/router. I created a pool on the Firewall for WiFi and some access policies. My questions are: 1. When I connect the R...
Nov 05, 2025Guru - Experienced User
Would be best to set up the Orbi system for AP mode and it's reqired to use the WAN port for the RBR connecting to the main host router:
Static IP Address Configuration for AP Mode | NETGEAR Communities
Not much to manage while in AP mode accept for wifi channels on the RBR unit.
Orbi AX systems have the main WLAN, Guest Network and a separate IoT network. Nothing can be VLANd for wifi on Orbi AX home systems.
RBS connection configuration will be based on placement to each other from the main router unit. Out in a line, that is daisy chain, out in star formation from the router unit, is non daisy chain formation/connection.
