MB_Love's avatar
MB_Love
Apprentice
Jun 17, 2020
Should I change channel?
I am wondering if it’s best to select your own channels or just stick with auto setting? While I was in front bedroom I realized we pick up a lot of the neighbors networks and not sure if this could be slowing my network down. Also, how do I chose best channel? I’m assuming once I find optimal channel I just go to OrbiLogin page and undo auto and select my own? Thanks !
  • plemans's avatar
    The problem with selecting your own is if your neighbors wifi is on auto and it switches around, it could end up causing more interference. I usually set mine on auto unless I know my neighbors have set their channel with a set channel and not auto.
    • Retired_Member's avatar
      Retired_Member
      2.4Ghz should only be channels 1, 6, or 11.
      5Ghz, I've noticed the lower channels perform better. I have mine set to channel 48. You can download an app on your phone to do a scan and see what channels are most popular in your area. Pick a channel that isn't being used a lot.
      • schumaku's avatar
        schumaku
        Probably because the lower 5 GHz channels are power restricted, and showing less bars on the mobile .. making them less "attractive" to select manually.
