lagenour's avatar
lagenour
Follower
Oct 05, 2022
Simplest way to swapout a AX4200 for RBS20 keeping names and passwords
Getting ready to swapout a AX4200 to replace RBS20 keeping names and passwords intact.
Seems I saw a procedure somewhere to do this simply.
I'm not an admin, just an old geezer looking for better coverage.
  • FURRYe38's avatar
    Follow the installation Guide. https://www.netgear.com/support/product/rbk752.aspx#docs
    We presume you mean the Orbi RBK7 series system?
    You can set up the new system using Orbi mobile app on a phone or pad or recommended setup would be to use a wired Pc and web browser. You can use same SSID name and password when presented with this option during the setup routine.
    • TC_in_Montana's avatar
      TC_in_Montana
      Virtuoso
      As FURRYe38 mentioned, you can use the same SSID name and password as on your original Orbi device.
      Most times, devices will connect with no issues; however, I have found that on occasion, I may need to turn on and turn off a device to get it to connect back fully.   Some devices remember not only SSID and Password, but also the MAC ID of the device it connected to.   So turning off/on that device allows it to reconnect correctly.   A few of the devices I have had to do this with are Netgear Meural devices and some GE wall switches.
  • CrimpOn's avatar
    CrimpOn
    There is some ambiguity in the question.  The standard practice when replacing one WiFi system with another is to give the new system exactly the same WiFi name (SSID) and password as the old.  (I have done this for over 15 years through countless systems.)  That way, all of the WiFi devices will detect the new WiFi and connect automatically.
    Any other configuration will be lost and have to be entered manually as there is no method to "save" the configuration from one model of router and reload it on another.  For example, I like to give my devices "names" that are more descriptive (Living Room Speaker, Mom's Printer, etc. etc.)  I also like to assign specific IP addresses to devices.  I also have OpenVPN and DDNS configured on the router, and have replaced the Spectrum DNS servers with CloudFlare and Google DNS. All of that information must be reentered.
