bmillz
Dec 15, 2023Follower
Slow speeds on RBR760
Hello, I’m in Canada, and have a shaw gen 2 XB7 wifi modem set up in the basement. Previously, I connected my ps5 (located 1 floor directly above) to this through 5 ghz wifi. This was giving me about 400 mb/s on playstation 5 speed test. The problem was the signal strength through the rest of the house was sometimes poor for phones, and occasionally I’d get some lag while gaming.
I went out and got an orbi rbr760 tri band mesh network with 2 satellites. So now the main router is wired to the shaw modem downstairs, and I placed 1 of the satellites right next to my ps5 upstairs and ran cat 5e between them. I figured this would be the same thing as before for ps5 (as the mesh is still wifi), with maybe a more stable connection due to the better antenna on the mesh setup vs the ps5, all while providing better coverage around the house.
I was expecting maybe a slight drop in speeds, but when I ran a speed test on ps5 I was only getting 70 mb/s through the orbi compared to the 400 from before just using wifi to the modem. Is there some setup/changes I need to make with the orbi settings potentially, or is this just standard for mesh setups?
I do have a coax outlet a couple rooms away I’ve already ran to the room with ps5 for cable tv, I heard that moca adaptors are good, is this option a lot better?
Thanks
Thanks
1 Reply
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...What Firmware version is currently loaded?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Basements are not recommended places for the RBR. All that concrete and steel will inhibit good signal travel and cause problems.
