Rossman
Oct 03, 2024Aspirant
Sold RBR750 To Friend
I sold my RBR 750 mesh system to a buddy. I removed it from my NETGEAR account, I factory reset the router and satellite. He went to set it up via Orbi app and for for some reason it’s still under my ...
Oct 03, 2024Guru - Experienced User
here's a guide on removing it from your an account.
Registration and Un Registering products Help - NETGEAR Communities
Rossman
Thank you for the reply, not to be rude but I already did that. Please reread what I typed.
- FURRYe38Oct 06, 2024Guru - Experienced User
If the linked process doesn't work for you, then you'll need to make contact with NG support for there help on this as this is beyond forum help.
Good Luck.
- RossmanOct 07, 2024AspirantThanks for the reply, yea I did all that and the netgear armor only allows you to delete devices that are connected to that router: PC/Phone/IPad etc. not the actual router/satellite itself. Like the one poster said above, I’ll most likely need to email netgear directly and have them remove it. Thank you for the information though.
