PaulO1804
Jan 20, 2021Aspirant
Solid magenta LED on new RBK753
Hi there, pretty frustrated at the moment. I replaced my working, but struggling BT Whole Home Wi-Fi mesh with the RBK753 and can’t get it to connect to the internet - the router just shows a solid magenta light - the 2 satellites seem ok. The app shows the router to be ‘offline’ but doesn’t give any guidance of what to do to resolve this. S
I’ve re-run set up a few times, deleted and reinstalled the app, pressed reset to restore factory settings and finally given up and gone back to my old BT mesh set up. I also continued to use the same Orbi- supplied cable when re-connecting the BT system - I’m now back online.
So I know it’s not the cable, it’s not the ISP provided router/modem on which I have the Wi-Fi signal switched off, it’s not the supply of a decent signal into my home because the BT system is now back up and running fine
It’s probably worth noting that when setting up the Orbi router the app at first couldn’t find it after 3 attempts but then randomly sorted itself out. But proceeding through the rest of the set up process, I got to the firmware update page and it just won’t update - I’ve tried about 5 or more times and each time it fails.
Any advice to resolve this will be much appreciated
- FURRYe38 I’m gonna close this and mark it solved and come back if I have any more issues. I probably won’t get a chance to fiddle around with the routers for another few days.
Thanks a lot for your advice, which really helped me sort this out
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If it's got a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- PaulO1804AspirantHi FURRYe38 thanks so much for taking the time to respond. I’m in the UK and the ISP is a company called PlusNet, and it’s their Hub One router I’m using.
I’ve had a look on their support community site and it doesn’t look like they support bridge mode for that device. I’ve also seen something on here saying you can’t use the netgear app if the RBR750 (or any of their routers) is in AP mode.
I think AP mode is the most straightforward option (I think) so the question is, will I have limited functionality if I can’t use the app, and if so what will I be losing?- FURRYe38Guru - Experienced User
The Orbi app is limited in any mode. Mostly to see what is connected, you can stop access per device, speed test and thats about it. The app works in both router and AP mode. At least on the 8 series Orbi. I presume 7 series it should as well since there both close in nature and HW san some wireless speed supported rates on 2.4Ghz and memory and LAN ports, FW is same code base. So the app should work on the 7 series as well.
