TheBlair21
Sep 27, 2021Tutor
Solid Magenta Light on RBR850 with no Internet
Hey, everyone
I am losing internet, and then I am finding a solid magenta light on my router only, no light on the satellite. I have the RBR850 (Orbi WIFI 6 with one satellite). My modem appears to be fine during all of this, all of the lights are functioning as normal. This is a new problem, happening frequently over the past few days. When I reset everything (powercycle the system) internet returns. So turning it off and back on works every time, but I am trying to figure out what the issue is so it doesn't keep happening. I appreciate all of your help!
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Be sure your using a good quality LAN cable in between the modem/ONT and RBR. CAT6 is recommended.
-V4.6.3.16_2.0.51
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?-Using my own Modem - Netgear CM1000
-Yes, I have had to powercycle everything several times. Three times last night and twice today, already. Turn off the Modem, Router, and Satellite. I let them sit. Then turn on the Modem until it completes its cycle. Then turn on the Router, followed by the Satellite. It works each time, but seemingly at random intervals, I notice there is no longer internet through the network and I find the Router with a Magenta light.
-Using a Cat6 cable.
-I should note, nothing has changed. This began seemingly out of the blue. Same Modem, cables, Satellite position. No changes to my knowledge, and I have not had issues like this before. Internet has always been strong and fast. I believe the firmware updates on its own, so I am curious if it has something to do with that. However, my scope of knowledge in networking is a bit limited.
One indiacation is that when the RBR is PINK, there is a problem at the modem. IF this came out of the blue and just started, possible ISP signal issue or modem issue.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853How long have you had the Orbi updated on v16?
