rchamrick
May 13, 2024Aspirant
Some devices cannot connect to ORBI RBRE960
In February, I upgraded to the RBRE960 router with one satellite. My new home has many smart features (including 57 smart lights, smart shades, ring floodlight network + additional ring devices, sma...
rchamrick
May 15, 2024Aspirant
Thanks. This morning all devices were functioning normally again, including my iPhone. Still, I called the ISP and implemented your recommended #2 option on the modem. Will keep fingers crossed that this prevents future problems.
Appreciate the help.
May 16, 2024Guru - Experienced User
Did you update the system?
- rchamrickMay 16, 2024Aspirant
I did not update the firmware. I did sign on to the modem webpage, but it also said there was no firmware update. I know that's not accurate, but I am not comfortable going through the manual download steps and, perhaps, having to restore the devices to factory settings. I'm sure I can follow the directions if needed and, if the problem recurs, I'll gather my courage and push forward with it!
Thanks.
- FURRYe38May 16, 2024Guru - Experienced User
