Deepak_Mehta
Mar 03, 2021Aspirant
Speed Issue
Hi All,
I have internet connection of 300 MBPS upload and download both for RBR850 , but still speed is not increasing more than 100MBPS
Is there any other settings to be done on the router.
I have a static ip connection.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Are you testing with a wired or wireless device?
Be sure your testing over a wired PC connection.
Make sure your wired network adapter is supporting of 1000Mbps and not 100Mpbs. Older network adapter cards were rated for only 100Mpbs.
Be sure your using good quality LAN cable. CAT6 is recommended.
- Deepak_MehtaAspirant
What Firmware version is currently loaded? ( Firmware Version V3.2.17.12_1.4.14)
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? (dbc connected with fiber optic and from there one output cat6 connected to RBR850)
Are you testing with a wired or wireless device? i have checked on both wired and wireless
Be sure your testing over a wired PC connection. (Checked on same)
Make sure your wired network adapter is supporting of 1000Mbps and not 100Mpbs. Older network adapter cards were rated for only 100Mpbs. ( Yes i had 1000MBPS connection)
Be sure your using good quality LAN cable. CAT6 is recommended.(Yes using manufactured cable)I am getting proper speed on my old device.
Sharing Net speed on old connected devices
